  4. Mitsubishi Robot Forum
Safe Position Output Signal
  • chintankAne
  • September 30, 2021 at 3:37 PM
  • chintankAne
    22
    How to Set Digital Output when robot at Safe Position?
  • asamu1234567890
    • April 15, 2024 at 4:46 PM
    Good question, i need to know it too. Did you solve this problem?
  • sCZot
    5
    54
    • April 16, 2024 at 7:51 AM
    hi, it really depends on the controler you are using
  • asamu1234567890
    • April 16, 2024 at 3:43 PM
    Im using FR-D series CR800-D controller and scara robot.
  • sCZot
    5
    54
    • April 17, 2024 at 9:44 AM
    well, generally speaking, you can't unless you have some sort of external periphery. In the R variants (with PLC on the same main base) you can use an internal bus for the signals, since you are using the D variant (standalone), you can use some Cc-link IE field BASIC peripheral (since this field bus is native to your controller) or use some of the highlighted parts from the attached picture.
    Images
      • 153.67 kB
      • 1,274 × 413
      • 11
Similar Threads
  • SafeMove: Synchronization vs Safe Zones
    • SkyeFire
    • August 4, 2021 at 11:45 PM
    • ABB Robot Forum
  • Cubic S Area Monitoring Functionality
    • aihfye
    • April 2, 2021 at 3:58 AM
    • Kawasaki Robot Forum
  • KRC4 Training safety wiring or programming in T1
    • dhracer3
    • March 30, 2021 at 10:40 PM
    • KUKA Robot Forum
  • How do I specify a Safe Home Output?
    • Cobotnik
    • September 20, 2020 at 8:12 AM
    • Universal Robots
  • Diagnostic signals via PROFINET
    • edda
    • September 8, 2020 at 2:09 PM
    • KUKA Robot Forum
  • Problema con saferdw
    • Francisco
    • December 6, 2019 at 11:04 AM
    • KUKA Robot Forum
  • How do I call routines in Karel code from the teach pendant job?
    • ashwinmudigonda
    • March 10, 2018 at 11:34 PM
    • Fanuc Robot Forum
  • Help setting up a zone to control press open/close function
    • jmax26
    • March 9, 2018 at 5:56 PM
    • Fanuc Robot Forum
  • 3 robots on thesame 7 axis
    • maxwell
    • November 14, 2017 at 7:23 PM
    • KUKA Robot Forum
  • IRC5. Safety_SyncWarn digital output
    • boldive
    • November 8, 2017 at 2:36 PM
    • ABB Robot Forum
  • Home Signal
