  4. Kawasaki Robot Forum
Kawasaki z130s transition speed between steps
  • Fatih54
  • September 29, 2021 at 1:16 PM
  • Fatih54
    21
    hello there
    I want to use my robot as a laser cutter. But the problem occurs because my transitions between steps are slow . Can we adjust the transition speed between the steps
  • kwakisaki
    694
    4,770
    • September 29, 2021 at 6:51 PM
    Quote from Fatih54
    What controller?
    What application is the controller set at?
    What problem is occurring?
    Why do you require to change speeds during the actual cutting process?
    What currently are you doing,, some code would be nice?
  • Fatih54
    21
    • September 30, 2021 at 7:34 AM
    Selamlar kwakisaki
    t52 denetleyicim var. robodk programı ile lazer kesim yapmak istiyorum. Adımlar arası geçişlerde robotum standart olarak yavaşlıyor. yani, adım durağına yaklaştığında ve adım başlar yavaştır. ortaya çıkan kesme bölgesi daha fazla bölgenin erimesine neden olur. bundan dolayı bir sorunum var
  • kwakisaki
    694
    4,770
    • September 30, 2021 at 9:47 AM
    Please post in English for your future posts here.
    Google translated:
    i have t52 controller. I want to make laser cutting with robodk program. My robot slows down as standard during transitions between steps. that is, when the step approaches the stop and the step starts is slow. The resulting shear zone causes more zones to melt. so i have a problem
    Robot Forum has a dedicated board for RoboDK questions:
    RoboDK - Robotforum - Support and discussion community for industrial robots and cobots (robot-forum.com)
    You have said you want to change speeds between steps, now you are saying something different.
    Which is it?
    - Change speeds between steps.
    - Prevent the robot from decelerating/accelerating during transition moves.
    Without you supplying an example of your produced code, there's nothing I could suggest.
  • Fatih54
    21
    • September 30, 2021 at 1:32 PM
    Selamlar
    Örnek bir program görüntüsü gönderdim. burada adım hızı değil. Aynı hızda 2 adım arasındaki geçişte robotta yavaşlama oluyor. bunu nasıl önleyebilirim
    Images
      • 473.57 kB
      • 1,200 × 1,600
      • 10
  • kwakisaki
    694
    4,770
    • September 30, 2021 at 1:46 PM
    POST IN ENGLISH
  • kwakisaki
    694
    4,770
    • September 30, 2021 at 1:53 PM
    Your code includes an initial statement of:
    ACCURACY 3.0 ALWAYS
    This means every position has an accuracy radius of 3 mm around it.
    Dependent on where there positions are in relation to the previous and the next invokes acceleration and deceleration between them.
    So to control them you need to understand just how Kawasaki AS Language operates.
    RoboDK is not a replacement for actual OEM learning.
    RoboDK does simple conversion and never replicates specific OEM functions and coding, unless applied during RoboDK programming and setup.
    You will be best to read/study the AS Manual and apply some of the command structures in RoboDK to appreciate the 'additional commands required' that RoboDK does not automatically apply and apply them in addition to what RoboDK generates.
    Again, RoboDK is not a direct comparison to OEM functions and features.
    If you wish to learn more specific capabilities of Kawasaki, you would be better to use K-roset which is the official Kawasaki OLP application provided.
    You can then apply what you learn of Kawasaki into the RoboDK environment and probably achieve better results.
    Additional commands may be required but not limited to such as:
    CP system switch
    ACCURACY command value increased.
    ACCEL/DECEL commands.
    ACCURACY command insertion between positions to 'blend them together'.
    System Settings for motion control improvements changing.
  • Fatih54
    21
    • September 30, 2021 at 4:35 PM
    thanks kwakisaki
    The information you gave will be useful to me. I tried croset but it is a difficult application. robodk can give us results in a simpler way.
  • kwakisaki
    694
    4,770
    • September 30, 2021 at 4:54 PM
    Quote from Fatih54
    Not in this case though.
    As explained, RoboDK (as with any robot within RoboDK) does not contain full functionality and options provided by the OEM and therefore has restricted application usage.
    For CAD to path and multiple points generation is great but not do not expect to just load into live robot and expect to work as settings/application/options in the live robot may influence results.
    This is where you need good understanding of Kawasaki function, programming and configuration so that if RoboDK cannot provide these, you would need to do yourself on Kawasaki instead.
  • Alexandru
    49
    407
    • September 30, 2021 at 6:28 PM
    You can increase the SPEED, you have 45 MM/S, and you can increase it, also ... it is better to use
    ABS.SPEED while cutting, i think this option is better.
    What is the monitor speed from the repeat mode?
  • Jeremy RoboDK
    17
    75
    • October 29, 2021 at 8:46 PM
    • #11
    You can try to increase the rounding settings in your Curve Follow Project (CFP) under "Program Events" -> "Set rounding".
    You can also open the generated program by "right-clicking" on it (the white one) and select "show instruction".
    You can then find your "set speed" instructions and modify the acceleration.
    The operation speed can be changed in the CFP and the transition speed in the CFP->Program events.
    Jeremy
    RoboDK - Simulation and Offline programming software for industrial and collaborative robots.
    Visit us at RoboDK.com
    Take a look at our tutorial videos on our YouTube channel.
  • kwakisaki
