Rmp of the robots
  • If you are going to run that fast, make sure to run a spindle warm-up program at the beginning of each day or you risk damaging your bearings. Colombo has a specific procedure outlined in their documentation that covers this.
  • Are you sure that the 1800 number is RPM? I have a robot that was integrated by the same integrator as yours and their "spindle on" program set a 0-20mA output. I.e, 0 = 0 and 2000 = max rpm. I made a program to convert RPM to AO signal to enhance readability - check your "AA_ON" program to see if it's doing an RPM to 0-20mA conversion or just setting the analog output to AR[1].
