Hi all!
I have a Kuka IIWA 14 robot. It started crashing some time ago, therefore I ordered a KUKA USB Recover Stick and reinstalled the WinC and WinD partitions on the controller. Everything seems OK so far. But there seems to be an issue with the smartPad.
On the controller (with the display and a keyboard connected) I cannot start the ApplicationServer or the smartHMI app - apps don't exist as shortcuts are pointing to the wrong destination. SmartPad boots to winCE and stays there, without any connection to Kuka PC and I think there is a problem. As far as I recall, it should mount a network drive from the controller and install the application. Then the controller is supposed to run the StartApplicationServer.exe and the HMI should appear.
If I try to connect from smartPad to krc (ip being 192.168.0.1), with credentials of KukaUser/KukaSystem/target etc., I always get an error about invalid certificate.
To recap:
- After USB Recovery procedure, the controller boots, ping to 172.31.1.147 works.
- SmartPad displays WinCE Desktop with no working application.
- Controller "StartApplicationServer" and "StartHMI" fails.
- SmarPad cannot connect (remote desktop or mount) to kuka controller.
Can I somehow fix the smartPad, or is the trouble somewhere else? Is there a way to recover a smartPad from a recovery USB?
Best,
Domen
