Hi all,
I made a simple place-part-in-box with 1mm clearance all around. BW CCD is fixed, box sits on a flat surface and Userframe is grid-calibrated. Rotation around the R-axis is clean, so TCP is fine. XY variations leave frame-offsets spot on, so Userframe is fine.
So how is it that offsets become up to 5mm off when box is rotated? I've tried turning orientation off and copying the reference every 30 degrees without changing anything else, no change in position: spot on. The problem begins when I turn orientation on, which seems to be the cause of my wrong-offset problem.
How should I go about fixing this?
Thanks in advance,
~ Tony
