Shifting multiple times [XRC SV3X]
  • matthias2021
  • September 14, 2021 at 3:57 PM
  • matthias2021
    I would like to shift a job multiple times. So it executes a job shifts by e.g. 100mm on the x axis executes the same job and shifts again by 100mm and again and again...
    I tried:
    NOP
    Sfton P100 (P100: X: 100mm rest: 0)
    Call Job
    Sftoff
    END
    NOP
    Sfton P100
    Call Job
    Sfton P100
    Call Job
    Sftoff
    END
    None worked it just shifted once by 100mm..
    Can somebody tell me what I do wrong?
    Thank you very much!
  • TSGIR
    81
    715
    • September 14, 2021 at 6:51 PM
    For correct working do same as below:
    Define two P variable, P099 (X=100, other =0) and P100 (all items zero)
    NOP
    SET B000 0 // reset counter
    SET P100 P099
    *LOOP
    SFTON P100
    CALL JOB:JOB ( your job that will shift)
    ADD P100 P099
    INC B000 // this is a counter
    JUMP *LOOP IF B000<3 // the job will shift for 3 times.
    SFTOFF
    END
  • TSGIR
    81
    715
    • September 14, 2021 at 7:09 PM
    For automatic reset the P100 variable, you can add below code after NOP in first of job:
    SUB P100 P100 // this code zero all items in P100 variable.
  • matthias2021
    • September 15, 2021 at 8:34 AM
    Works perfect :smiling_face: Thank you
  • Boring_robot_guy
    36
    • September 15, 2021 at 12:54 PM
    You are not able to shift on multiple position variables in the same frame. If you have multiple base frame shift on, the system takes the last one shifted on. You could shift on data in base frame, robot frame and user frame all at once and would work as well.
  • Emre64
    59
    • September 15, 2021 at 3:23 PM
    I use this sample too.
    Thank you TSGIR.
  • XRC
  • SV3X
