Alarms to PLC
  • white_raven
  • September 13, 2021 at 10:03 PM
  • white_raven
    8
    64
    I was just wondering if it is possible to send specific alarms to a PLC for monitoring purposes. Like lets say we have a 1325 Communication Alarm. Is there a way for the robot send that alarm code to the PLC or will I have to get crafty and write some type of background logic to run and send the information for each individual alarm in a binary system?
  • 95devils
    235
    8
    1,951
    • September 13, 2021 at 10:54 PM
    Not knowing what generation you are on, it is possible. There are M-registers that contain the alarm number. If you look in the Concurrent IO manual for your generation it will have the address. This could be passed to the External Outputs and on to the plc.
  • TSGIR
    81
    715
    • September 14, 2021 at 9:21 AM
    If you use Modbus Tcp for communication between robot controller and PLC, you can send very easy the M-register that show alarm code.
    Alsoyou can send M-register data to external i/o but it need more i/o for it,
    There are other way and is use the Ethernet IP.
  • white_raven
    8
    64
    • November 15, 2021 at 5:26 PM
    Quote from 95devils
    I am on an NX100 right now and the M registers for alarm information are M340-M342. How would I write that into the ladder edit to send the M registers to a PLC? I've read through the concurrent IO manual but I can't quite figure out how to get the M registers output to a PLC. I'm using CC-link connectivity to the robot so it would most likely have to be binary correct? I'm just not sure how to write the instructions to output that information. Any help or clarification of my misunderstandings would be greatly appreciated.
  • 95devils
    235
    8
    1,951
    • November 15, 2021 at 9:11 PM
    Use the MOV instruction in the ladder to move the contents of the M-register to a relay word.
  • white_raven
    8
    64
    • November 16, 2021 at 3:40 PM
    Quote from 95devils
    I tried this but I get an error when I save. Where do I move the contents to so I don't get an error and so the PLC can read the information? Which outputs should I move the contents of the register to?
  • 95devils
    235
    8
    1,951
    • November 16, 2021 at 4:27 PM
    The error was probably when you compiled. If you set the output as a relay word, it is going to be 16 bit. You need to make sure the group you are using as the output and the next group are not used in the ladder.
    The outputs need to be on your CC-Link network.
  • white_raven
    8
    64
    • November 16, 2021 at 6:35 PM
    Quote from 95devils
    Ok thanks for the reply, however, virtually all of the outputs are being used somewhere in the ladder. For example: it will show a universal output # in a GRP instruction then an external output # on the bottom. I don't really understand what the point of this is or if it will destroy anything if I delete the instruction so that I can utilize the output. This is my first time actually modifying the ladder portion and it has been almost a decade since I took the class. My manual also doesn't clarify things very well so any help with this is greatly appreciated. Here is an example of the instruction I'm referring to. Ladder.png
    Edited once, last by white_raven (November 16, 2021 at 6:40 PM).
  • 95devils
    235
    8
    1,951
    • November 16, 2021 at 8:22 PM
    Yes, you are needing to delete the next group from the ladder. The MOV instruction is a 16-bit instruction. To send over a 16-bit alarm code to 16 outputs (2 groups) the outputs can not be addressed somewhere else.
    Using the GRP addresses that are shown above. The MOV instruction would move the alarm register into relay word 30170. Group 30171 would need be removed from the ladder.
  • white_raven
    8
    64
    • November 16, 2021 at 9:13 PM
    none of that worked and I still get a fault that simply states "relay number" with no detail whatsoever. The relay isn't being used anywhere else and I just give up at this point. Getting the alarm information sent to a plc isn't going to happen I guess. Here are pictures for reference.
  • 95devils
    235
    8
    1,951
    • November 16, 2021 at 9:29 PM
    • #11
    Need to move to an external output address. You can only output to a 0,3,4, or 7 address.
    0 Universal Input
    3 External Output
    4 Specific Input
    7 Auxiliary Relay.
  • TSGIR
    81
    715
    • November 17, 2021 at 8:57 AM
    • #12
    if use "MOV M340 W#30030", it work correct.
    there are a notice, if the #30030 use in ladder before, you couldn't use here and will give new error message.
  • mil3k
    21
    85
    • November 18, 2021 at 10:10 AM
    • #13
    Quote from white_raven
    I feel your pain... but I din't give up. Double check if you don't have BMOV instruction used somewhere in the CIO file. If you have it ensure to release desired range of source/destination relays from it and then try again.
    I had BMOV #20520,158,#00500 and wanted to link 8 groups (64bits) of internal relays with general purpose inputs started from #00730. When I started I had an error during compilation, something about illegal, double use of relay. For some time, I couldn't find to what relays that alarm was related to. Because #00730 was in the middle of BMOV instructions I couldn't find it.
    So when I figure it out, I did below:
    1) Found BMOV instruction where desired inputs were used.
    2) Split it in two BMOV instructions:
    BMOV #20520,22,#00500
    BMOV #20740,114,#00730
    3) Compile and check if everything is still as it was.
    4) Release first 8 bytes from second instruction
    BMOV #20830,106,#00810
    5) Compile and check if no error and release groups are free to use.
    6) Link groups of auxiliary relays (internal) with groups of GP Inputs
    STR #70017
    GSTR #76650
    GOUT #00730
    GSTR #76660
    GOUT #00740
    GSTR #76670
    GOUT #00750
    GSTR #76680
    GOUT #00760
    GSTR #76800
    GOUT #00770
    GSTR #76810
    GOUT #00780
    GSTR #76820
    GOUT #00790
    GSTR #76830
    GOUT #00800
    STR #70017
    7) Compile and check if everything works as I wanted.
    Good thing is that you need to do it only once, after that you can just use your CIO file with every other robot or just copy and paste this section to new robot's CIO file.
    Now, after above modification in the CIO file, if I would like to have on my GP Inputs alarms I could try this:
    1) Add these three lines
    MOV M340 W#76650
    MOV M341 W#76670
    MOV M342 W#76690
    or 2) remove links I did in step 6 and use instead:
    MOV M340 W#00730
    MOV M341 W#00750
    MOV M342 W#00770
    Edited once, last by mil3k (November 18, 2021 at 10:35 AM).
  • 95devils
    235
    8
    1,951
    • November 18, 2021 at 12:58 PM
    • #14
    Quote from mil3k
    STR #70017
    GSTR #76650
    GOUT #00730
    GSTR #76660
    GOUT #00740
    GSTR #76670
    GOUT #00750
    GSTR #76680
    GOUT #00760
    GSTR #76800
    GOUT #00770
    GSTR #76810
    GOUT #00780
    GSTR #76820
    GOUT #00790
    GSTR #76830
    GOUT #00800
    STR #70017
    MOV M340 W#76650
    MOV M341 W#76670
    MOV M342 W#76690
    MOV M340 W#00730
    MOV M341 W#00750
    MOV M342 W#00770
    OP is on NX100 which doesn't have the BMOV instruction.
  • mil3k
    21
    85
    • November 18, 2021 at 2:51 PM
    • #15
    Quote from 95devils
    Thanks for info, I wasn't aware about it.
    Just dug through my manuals and DX200 is the first generation where I found BMOV.
  • 95devils
    235
    8
    1,951
    • November 21, 2021 at 4:52 PM
    • #16
    Here it is is the simplest form. In this example I am writing to 30030. Since this is a 16-bit MOV instruction I need to make sure that addresses 30030 through 30037 and 30040 through 30047 are not used anywhere in the ladder. The only other item I add is another NO (A) contact in parallel that is my alarm reset button. This will reset M640 and clear the outputs.
  • notverycreeative
    • December 5, 2021 at 1:55 AM
    • #17
    If your PLC and Robot are both using Ethernet/IP then there is an Explicit Message configuration in the PLC that you can use to read the Alarm. I believe this topic is addressed in one of the Ethernet/IP manuals.
    According to the manual it is not supported with any robot that has Safety Over Ethernet (FSU Ethernet Safety).
    I have tried to implement it in the past, but have never had the time to figure out how to make it work. We read the alarm codes out of Fanuc robots all day every day though with a similar process.
  • white_raven
    8
    64
    • December 8, 2021 at 2:22 PM
    • #18
    Quote from notverycreeative
    We only use discrete IO, and do not have ethernet connectivity between the robots and PLC.
Similar Threads
  • DX100 Position Error?
    • DKirkman
    • September 2, 2021 at 1:10 PM
    • Yaskawa Motoman Robot Forum
  • Using Style call and resuming cycle after leaving program or abort
    • SmoothJazzRobot
    • September 9, 2021 at 3:24 PM
    • Fanuc Robot Forum
  • yrc1000 HC10
    • GWrobo
    • August 24, 2021 at 1:01 PM
  • Help setting up our (first) used robot
    • GiroDyno
    • August 10, 2021 at 7:06 PM
    • Fanuc Robot Forum
  • ERC controller, Need Help Alarms 0853, 0963 at Servo power up.
    • danc@rosemetal.com
    • July 20, 2020 at 7:31 PM
  • sending active alarms to PLC through profibus
    • RKind
    • November 22, 2018 at 7:55 AM
    • Fanuc Robot Forum
  • Remotely clear alarms DX200
    • Crowmagnus
    • November 6, 2018 at 4:50 PM
  • RJ3 TP alarms
    • stonetech
    • August 7, 2017 at 3:17 PM
    • Fanuc Robot Forum
  • NX100
