Formcut not appearing in XRC-2001 inform list
  • Hello I’ve been trying to get formcut to work on any one of my 3 xrc-2001s for two days now. I have XXX set to 1 and XXX set to 1 but Formcut will not show up in my options. A Yaskawa tech said that some early software versions didn’t have formcut but I believe my software versions are of the newest, and no one seems to think it’s an add on software option, just an enable and you’re good to go kinda thing. I was about to throw up my hands and say the tech was right but then I went to my application menu and there’s the formcut spec file. Logic would point to I’m neglecting something as a software version without formcut wouldn’t have formcut settings in application. I go to inform list- motion, formcut should be below REFP but the list ends there. I have instructions set for expanded as well in teaching condition.
    Anyone have any thoughts as to what my error is?
    Thanks,
    Andrew
  • What software version are you using? I remember X8.00 being out and about X6.38 being near the end for general public.
    Formcut was not an add-on. The software has it or it doesn’t.
    Do you any Formcut instructions in the INFORM LIST, OTHER?
  • My software build is x6.37(JP-US)-00, parameter 3.21.
    I’m told that this is the most common version. The only thing appearing in INFORM, OTHER is SHCKSET and SHCKRST. Right,and I can’t imagine the software doesn’t have it if it has the Form cut file setting.
    Thanks,
    Andrew
  • Try going to SETUP, TEACHING CONDITIONS. Go up the Menu Area and see if there is a rebuild under data.
