Destination Pulse Limit in DX200
  • Gurtej Singh
  • September 10, 2021 at 5:18 PM
  • Gurtej Singh
    29
    Hi everyone,
    So I changed D variables from my computer and then I am trying to do following to create a position variable out of 6 :
    NOP
    SETE POO2(1) DOO1
    SETE POO2(2) DOO2
    SETE POO2(3) DOO3
    SETE POO2(4) DOO4
    SETE POO2(5) DOO5
    SETE POO2(6) DOO6
    MOVJ P002 VJ=50.00
    END
    and also I tried:
    NOP
    SETE POO2(1) DOO1
    SETE POO2(2) DOO2
    SETE POO2(3) DOO3
    MOVJ P002 VJ=50.00
    END
    But I am having same error:
    ALARM 4980: DESTINATION PULSE LIMIT
    [R1: MIN SLURBT, MAX SLURBT]
    I think its because of Rx, Ry and Rz as I read in this forum. But I have no idea how to fix that any help would be appreciated.
    Best Regards
    Gurtej Singh
  • Go to Best Answer
  • TSGIR
    81
    715
    • September 10, 2021 at 5:59 PM
    Your problem is in status of P002, it is in PULSE type and you are input value for x, y,z, rx,ry,rz.
    You must change the type of P002 to ROBOT type.
    You can write below code in first step,
    GETS PX002 $PX001
    SUB P002 P002
    CNVRT PX002 PX002 RF
    With this code the P002 will be to ROBOT type and you can get data from D variable.
  • Gurtej Singh
    29
    • September 10, 2021 at 6:27 PM
    thanks for your response .. i checked the type of P002 it is BASE type .. i tried changing the type to ROBOT and then MOVJ P002 didn't got inserted in INFORM code.. so now i switched it back to BASE type and i will try with this code line now
  • Gurtej Singh
    29
    • September 10, 2021 at 6:35 PM
    I tried the code and now i can see P002 variable changed to ROBOT type but I am still having an error:
    [R1: MIN SLURBT]
    But last time before changing it to ROBOT type it was coming :
    BR
  • TSGIR
    81
    715
    • September 10, 2021 at 6:37 PM
    Please check the D0## values, maybe the value that you will input to P002 are not correct and are more than moving range of each axis.
    The note is value for X, Y,Z are in 0.01 unit and Rx, Ry and Rz are in 0.001 unit.
    Lemster68
    301
    2,490
    Blog Articles
    7
    • September 10, 2021 at 6:38 PM
    What are the values stored in D001-6?
  • Gurtej Singh
    29
    • September 10, 2021 at 6:43 PM
    I can change them from PC but right now the values are 1,2,3,4,5,6,7,8 from D000 to D007
  • TSGIR
    81
    715
    • September 10, 2021 at 6:44 PM
    You couldn't give this value, you must give value in motion range of robot, the alarm is because incorrect value.
  • Gurtej Singh
    29
    • September 10, 2021 at 6:47 PM
    Can you give me a little idea about what values should I try.?
  • TSGIR
    81
    715
    • September 10, 2021 at 6:59 PM
    For best test,
    Step1: go to P variable, move robot to any position do you want, change the type to ROBOT and press MODIFY + ENTER, the value of robot show in X, Y, Z , Rx, Ry and Rz in position variable.
    Step 2: move the robot to any position,
    You can give value in the P variable that you set in Step1, the value in X of P variable set in D000 , Y set in D001 , Z set in the D002, Rx set in D003, Ry set in the D004, Rz set in D005.
    Know you can send the value in D000 to D005 from PC to P variable that you want.
    Example,
    P001 is a position of robot,
    X = 986.765
    Y = 234.657
    Z= 432.123
    Rx= 180.0000
    Ry= 90.0000
    Rz = 59.3245
    You must set each value in D000 to D005 ans send from PC to robot.
    D000 = 986765
    D001 = 234657
    D002= 432123
    D003 = 1800000
    D004= 900000
    D005= 593245
    I hope you understand this example.
  • 95devils
    235
    8
    1,951
    • September 10, 2021 at 7:02 PM
    • Best Answer
    • #11
    Quote from Gurtej Singh
    Not knowing what size robot you have makes this difficult. Go to ROBOT, CURRENT POSITION. Change the format to the same as your position variable. Write down the numbers. In the D-variables you need to account for decimal places. 5000=5 mm on XYZ. 10000=1 degree on Rx, Ry, and Rz. Put those numbers into your D-variables. Jog your robot somewhere. Then move to your P-variable to test.
  • Gurtej Singh
    29
    • September 10, 2021 at 7:59 PM
    • #12
    Quote from 95devils
    Quote from TSGIR
    For best test,
    Example,
    X = 986.765
    Y = 234.657
    Z= 432.123
    Rx= 180.0000
    Ry= 90.0000
    Rz = 59.3245
    D000 = 986765
    D001 = 234657
    D002= 432123
    D003 = 1800000
    D004= 900000
    D005= 593245
    Thank you so much.. I learned about it and successfully robot is moving from external parameters.. really big big thanks .. i will come with new problem in new thread :face_with_tongue:
    This is issue is resolved thank you so much once again!!:smiling_face::smiling_face:
    BR
Similar Threads
  • Alarm 4980 on DX200 Controller
    • nate4g63
    • June 4, 2020 at 3:37 PM
    • Yaskawa Motoman Robot Forum
  • Yaskawa dx200
  • Yaskawa Motoman
  • Alarm 4980
