continuous speed tracking tool
  • Hello.
    I'm currently working on a project in which the speed of a custom build tool needs to be measured continuously while the arm is executing a program and then output the speed to an external controller(arduino) so it can adapt some settings based on how fast the tool is moving. I have never worked with a fanuc before. After searching on google I found that tracking the system variable $SCR_GRP[1].$MCH_SPD in a background program would allow me to continuous measure the tools speed. However I can find no further explanation on how it to do this and how I can output the measured speed through I/O.
    Can someone explain me how I can track the $SCR_GRP[1].$MCH_SPD variable and then output it?
  • Place your Ad here!
  • You can copy it to a Register or GO in BG Logic program.
    There is also a paid option called TCP Speed Output. It is similar but doesn't require a program, instead it has a setup menu. It is more accurate and also allows a speed prediction time offset to account for accel/decel.
