I have two robots that are using 3dl already. I need to add a GigE camera to each with higher focal length lenses to do a quality check. I successfully added a Basler acA1300-30gm that I was able to borrow from another robot and it worked flawlessly.
Now I got a sticker shock when I got a quote from Fanuc for the acA1300-30gm cameras, I thought they would be a couple hundred dollars. I tried sourcing it from other vendors, but the lead time is very long. In addition, I found out that the camera is obsolete.
So here are my questions:
- can I use third party GigE cameras or do only specific ones work? Any direct replacement for the Basler acA1300-30gm?
- if its only specific ones, would the acA1920-48gm work for all robots or only specific versions. It was specifically mentioned by a guy from Fanuc to work for this application, but I would want to make sure that it works for another robot in my plant as well.
Thanks in advance
