Setting P variables from D or B variable
  • Gurtej Singh
  • September 5, 2021 at 6:16 PM
  • Gurtej Singh
    29
    Hi everyone,
    I want to set P variable using D variables in INFORM for my DX200 controller. I am changing D variables from my computer and would like to use them for changing P variable. Any help would be appreciated.
    TIA
    Gurtej Singh
  • 95devils
    234
    8
    1,947
    • September 5, 2021 at 6:32 PM
    Use the SETE instruction in ARITH. Depending on the format on the P variable the elements are 1 is S, 2 is L, 3 is U and so forth. If the P variable is XYZ, 1 is X, 2 is Y, 3 is Z and so forth.
  • Gurtej Singh
    29
    • September 6, 2021 at 5:28 PM
    Oh wow thank you so much ..it worked really fine.!!
    Can we use this way for getting velocity from D variables also..?
    Quote from 95devils
  • 95devils
    234
    8
    1,947
    • September 6, 2021 at 7:55 PM
    For velocities you can use an Integer or a Double.
    MOVJ VJ=D000
    MOVL V=D000
    You have to take decimals into account. On a VJ there are two decimal places. On a V= there is 1. On a V= the controller uses mm/sec regardless of what you are using.
    D000=1000
    This would be the equivalent of MOVJ VJ=10.00 or a MOVL V=100.0 mm/sec.
  • Gurtej Singh
    29
    • September 6, 2021 at 8:09 PM
    Thank you for this info i will try it !!
    And last thing .. can we copy data from B variable to D variable using SET or is there some other things to be considered..?
    BR
  • 95devils
    234
    8
    1,947
    • September 7, 2021 at 12:14 AM
    Yes, you can use the SET to copy the content’s box of a Byte into the content’s box of a Double. If you need to do addition, subtraction, multiplication, or division you can also use the SET with the EXPRESS tag to reduce the number of instructions.
  • Gurtej Singh
    29
    • September 10, 2021 at 1:51 PM
    I tried to copy content of B000 to D000 using : SET D000 B000 but it came up with error: 2080 (Depress INSERT or MODIFY)
  • 95devils
    234
    8
    1,947
    • September 10, 2021 at 2:15 PM
    You are simply trying to add an instruction and the cursor is not right above the END instruction. Press INSERT then ENTER.
  • TSGIR
    81
    714
    • September 10, 2021 at 3:11 PM
    When you will add new instruction that aren't in the job content, press INSERT + ENTER.
    When there are instruction in the job content and you will change sections of it, after change press MODIFY + ENTER.
  • Gurtej Singh
    29
    • September 10, 2021 at 4:58 PM
    Quote from 95devils
    Quote from TSGIR
    Thank you so much it worked perfectly fine this issue is resolved !!
  • Abbas Aqapour
    • November 18, 2023 at 11:03 AM
    • #11
    what is different between B and LB and LB[] and so on?
  • Robodoc
    56
    7
    1,059
    • November 18, 2023 at 2:02 PM
    • #12
    any variable with an "L" is local to that job only and must be setup in the job header before you can use it.
    Any variable with "[ ]" is for array addressing.
    Variables without an "L" are global so any job can have access to them.
    Robodoc
  • Yaskawa dx200
  • Yaskawa Motoman
  • P variables
  • D variable
  • B variable
