Safety configuration tab is not active
- Dzonzi
i would check security settings or different user
What is security settings? Rights managment? There is nothing about safety. I tried others user....
yes, rights management. that would be the main reason menu entry is disabled (grayed out)
Did you log in as Safety Maintenance?
There is nothing there. Could be my OL broken?
Of course I did
...you never mentioned this was OL instead of a real robot. Details matter.
why can't you communicate that at the begin of the thread?
is it really that hard to post all relevant info about the system? did you ever read READ FIRST?
OL and KRC are NOT the same thing. in OL there is no hardware, no safety circuit, etc.
therefore there is no safety configuration in OL, so this menu entry is ALWAYS disabled.
I instered a screenshot....
that is not explicit enough and it is easy to miss. do not assume or make it hard on those trying to help you. nobody ha time to follow all little clues and decipher what you got yourself info..
Why can't I edit the corners? I can only drag the corners by mouse which is not the most precise way....
OL Documentation:
KUKA OL and SimPro are very primitive as i can see.
every simulation has limitations. and they may not be always easy to compare.
OL is not a physical model simulator -- it's basically a system for running robot programs without a robot (physical or virtual). As such, there's no way for it to provide a simulation of SafeOperation properties, and it's not intended for that use either. It's purely a software debugging tool.
SimPro might simulate SafeOp models, I'm not sure, never tried it. But even then, given how no simulation is 100% accurate to the real-world robot motions, it's still required (by RIA 1506) to test Safety elements by hand, on the real hardware, with the real working payload.
SkyeFire and panic mode are right for shure, but if one only read the advertising of Kuka:
"Each KUKA System Software release is available in full with all of the functions (a hardware periphery connection is not possible)"
One can imagine that Safe OP should be possible to simulate. And other robot offline programming tools can do safe configuration and simulation.
As always in commerce: don't trust advertisements
