hello everyone,
don't have access to KSS8.6 and my OL is only 8.5 so cannot do tests myself. but i am trying to assist someone who is far away and not used to dealing with this kind of things.
we have used for years sets of files on KSS8.2 and 8.3 but with KUKA moving to Win10 file format changed. Newer UserTech now uses XML version of configuration files... (we have 4.0.15)
Questions:
1. Are there any other options (command line switches) for conversion utility "KukaRoboter.UserTech.KfdConverter.exe"? running with -h or --help shows not much.
2. KFD is apparently converted, with some exceptions (PROSTATEO is now PROSTATE0) which should not be a show stopper. but trying to convert CONFIG file is not going well. according to manual this conversion is supposed to be manual, place file in C:\KRC\USER and then run conversion utility but - nothing happens... and log also shows nothing:
QuoteStart converting menu entries ...
Finished converting old menu entries with 0 error(s).
for which menu entries, if any, conversion was attempted? if there are no errors, does it mean it was successful? where are the output files? if no menus that need conversions are found, why it does not tell that explicitly?
