Robot: KR6R700-2
Controller: KRC5Microcontroller
KSS: KSS 8.7
I am trying to find a function in KRL, which would help me fetch all the 8 different solutions for a given (xyzabc). Does anyone have any idea?
Robot: KR6R700-2
KSS: KSS 8.7
INVERSE function. Just use forum search with this keyword.
Fubini
Robot: KR6R700-2
KSS: KSS 8.7
Assuming you are searching for axis solutions to a given Cartesian position, Fubini is correct. You will need to call INVERSE several times, sending it a different starting pose (S&T values, mainly), once for each unique solution.
Keep in mind, there will likely not be 8 axis pose solutions for every Cartesian position. Depending on your active $TOOL and $BASE values, some Cartesian positions may only have a subset of valid axis poses.
What do you want to achieve?
The INVERSE function is one way to get one result
Problem:
your 8 solutions are actually "mechanical solutions" (you can see them by checking the the mechanical position of the robot)
Actually you may have up to 48 solutions (you may or may not reach all of them (your question was not very specific))
How do I get to 48:
A1, A4 and A6 may rotate more than 180 degrees in plus or minus direction
Do you want to get all of them? Or just the one closest to the previous position?
INVERSE will give you only valid values or error message!
I am not working for them!
Using RoboDK with your robot you will be able to find all valid settings (and they could be more than eight)
You should be able to do that with the free version and just a few lines of code using the API.
Look at this section of our documentation:
https://robodk.com/doc/en/PythonA…nk.Item.SolveIK
You should use this one to get all the results at once:
Should give you what you are looking for.
Jeremy
Hey, i tried this, but i am the robot model i am looking for (KR6-R7002) is not available.
can you share me the code?
I cannot share the code with you.
You can check on Github to find some explanation like example
... i am the robot model looking for (KR6...)
you are, eh? fascinating...
Sorry for my typo
The example in #9 shows the way and formulas for forward and inverse kinematics of a kr210R2700.
the data needed for your robot are shown here kr6r700-2
you also can search for tools like
Robotics Toolbox | Peter Corke
ROS.org | Powering the world's robots
The Orocos Project – Smarter control in robotics & automation!
There are also documents covering your problem and you may check youtube for inverse kinematics
hey can you elaborate me more on usage of status and turn to get 32 or 48 solutions
Turn:
if axis value < 0.0 then turn = 1 otherwise 0
Status:
You have 8 mechanical (or physical) solutions
Axis 1: Front/Rear
Axis 2: Elbow up/Elbow down
Axis 5: Flip/no Flip
So you have 2*2*2 = 8 solutions
Depending on the software limit switches you may get more solutions:
If the software limites switch for axis 4 is set to +/- 350 deg you will get
2*2*2*2 =16
and in addition
If the software limites switch for axis 6 is set to +/- 350 deg you will get
2*2*2*2*2 = 32
is there print statement in krl?
is there any simple 1 can print out all 32 solutions in an easy way ?
should I keep turn as constant and vary status or
other way around?
Quoteis there print statement in krl?
Yes, see MessageLib.
Quoteshould I keep turn as constant and vary status or
other way around?
Transformation only uses status. Turn is something applied after the transformation is done so start with Status.
Fubini
There exists a KRL Library which can be very helpful.
Check krl libs for "g2_roblib.src"
Normally you would have Status:
A1: Front
A2 pointing up and A3 pointing down (positive value for A3)
A5: depending on the tool configuration you have
