Hello everyone. I need help. In the motosim program, I built a cell. The robot on the portal is inverted. How to set up the robot's coordinate system correctly. So that the Z axis is directed up and not down like mine. Controller NX100 robor HP20
Need help with offline programming
A_ghost -
August 24, 2021 at 1:32 PM -
It is a Yaskawa parameter that will flip the robot frame around. Since this is an old controller are you setting the MotoSim cell up as an actual running cell?
Can you tell me which parameter is responsible for this??
I am building a new cell by analogy with the real one, I tried to create an error from the ALL.prm file of the robot.
No. It is a parameter that an end user doesn’t have access to.
So to create the correct cell, I need to use a real ALL. PRM ?? And what to do with the error in Motosim??
Use the cmos.bin file from the real controller. If the robot’s frame is rotated 180 degrees then the virtual robot will be the same. The cmos will bring in everything from the real controller.
I'm sorry for the stupid question, but how do I save the cmos. bin file from the NX100 controller ? There is no such file in the folders in the picture.
It's in Maintenance mode.
Turn the controller off.
Press and hold the MAIN MENU key down.
Turn the controller on. Once you see the blue screen you can let go of MAIN MENU.
Put a CF card in the pendant.
In the Main Menu go to TOOL. This may say FD/CF, depending on how old the software is..
Press COMPACTFLASH in the sub-menu.
Cursor to CMOS SAVE.
Press the SELECT key.
Press "YES" on the box asking to SAVE.
At the bottom of the screen there will be a message, "Saving system data. Please don't shut power off." This message is replaced with "Maintenance Mode" and the pendant beeps when complete.
Thank you
