Hi Everyone,
Has anyone ever used IFM Al 1122 with Fanuc Scanner?
I think my problem is parameters entered manually on teach pendant from eds file.
I can ping the device from teach pendant.
Thanks in advance.
Hi Everyone,
Thanks in advance.
Hey, I'm quite curious if you have been able to solve your issue ? How did you make it ?
Yes I work with them on AB. Quite easy to integrate. I would like to use it on a project where I dont have a PLC on it. I want to try it to retreive a value of a keyence laser.
just to bump this topic, lets say i have a laser distance sensor connected through the io link, how can i read the distance value and used it in FANUC TP program? the distance value is taking up two bytes.
Is it that i need to setup at Analog Input /Output or I can only access through DI/DO?
Use group inputs.
Interestingly, Vendor Id, Device Type, Product code all set to 0s and it worked.
Sorry for the late reply.
