Fanuc change collision sensitivity r-30ib plus
  • I am using some 3d printed grippers on my fanuc robot. These are softer than metal, and when a collision occurs, they tend to bend. Is there a way to make the collison detection force more sensirive, so that the robot detects lesser force on the grippers and stops the robot? Thanks
  • As neighbour1 mentioned, first make sure your payload settings are correct and accurate.
    You can control the collision guard in your program with COL GUARD ON / OFF and COL GUARD ADJUST. A higher value means higher sensitivity. The default value is 100.
    Edited once, last by DS186 ().
