I am using some 3d printed grippers on my fanuc robot. These are softer than metal, and when a collision occurs, they tend to bend. Is there a way to make the collison detection force more sensirive, so that the robot detects lesser force on the grippers and stops the robot? Thanks
Fanuc change collision sensitivity r-30ib plus
robotrev3 -
August 23, 2021 at 5:18 PM -
menu > setup > coll guard
You can change the sensitivity
SkyeFire
August 24, 2021 at 6:15 PM Moved the thread from forum RoboDK to forum Fanuc Robot Forum. -
But mind that you need to adjust proper payload first, because otherwise collision detection will not work properly.
As neighbour1 mentioned, first make sure your payload settings are correct and accurate.
You can control the collision guard in your program with COL GUARD ON / OFF and COL GUARD ADJUST. A higher value means higher sensitivity. The default value is 100.
