Can anybody help me getting the pulses/degree for a MH12?
Hi
What do you what to do, please explain more.
Do you want to see value for each axis?
Where do you want to have?
Let the controller do most of the work for you.
Turn on ALL AXES ANGLE DISP, if it is not turned on under SETUP, FUNCTION ENABLE.
Go to ROBOT, CURRENT POSITION. Under DISPLAY is ABSOLUTE ANGLE.
Jog an axis until it stops. Record the pulse count and degrees. Jog the robot the other way until it stops. Record the pulse count and degree.
Figure total pulse and total degrees and divide out.
