Hello everyone,
I am new with the robotics and I wanted to know how to connect a Fanuc Robot and Siemens PLC 1500
Thank you very much
Hello everyone,
Thank you very much
You need to buy Profinet card and Profinet software from Fanuc.
How can I check if there is already a card and soft installed?
Thank you
PS: When I go Menu > IO > next, I have Profinet PFN-TP-CT
Does that mean that I can connect the robot to PLC by Profinet?
You can check what options you have installed by pressing MENU > 0 > 4: STATUS > Version ID > Softkey F3 CONFIG. There will be a list of every option installed.
When there, how to find out wich comunication protocol is installed?
Edit: I have "Dual Chan. Profinet" and PROFINET CP16XX FW, Is that what I need?
Thank you
Yes. But configuration is a bit fiddly.
My bad,
Do you have any doc or advise?
You can get the documentation from Fanuc customer support. Register to https://www.fanucamerica.com/support/robot/cc-registration or https://my.fanuc.eu/.
I am already redistred, and account validated by Fanuc,
I can see documents, but I am not able to find the right doc for this
Could you give me the doc name please?
It is B-82864EN/06
I am still struggling with network setup,
How can check that I have Profinet Hardware & Software installed in the the Controller?
Thanks a lot
I have a doc to configure it, but I don't really now if I have Profinet Software&Hardware installed?
How can I check if I have these?
Thank you
Thank you
Its been a while for me but , do you have a profinet option on Menu > (5) I/O > (0) Next and here you should see PROFINET.
Its better if you look in the software info as RockemSockem told you.
Here you stated that you have cp16xx, now again you don't know?
Post a picture of your controller, and the version IDs.
Yes, I have that options, but I don't see the CP16xx when I open the cabinet, so it's a bit confusing.
Here are the pictures
You have the Molex option (Dual Channel Profinet, R834). Option J744 is just the firmware of the Siemens CP16xx located on the controller.
The other picture shows the Molex card. You will find the steps for configuration in the PROFINET manual. See your other topic for information about the GSDML file. I already answered this question in the second thread.
Thank you,
I read you answer there, but I have no idea in how to customize and GSDML.
thanks
You don't need to create your own GSDML file for the Molex option. This is only required for the Siemens CP16xx.
Okay, thanks,
Where can I find the right GSDML?
