I think you would be better of getting a separate power supply.
- HawkME
- Thread is Unresolved
Why do you think so?
If you ruin the power supply of the robot it will probably cost you much more to replace than to just buy a 24 power supply in the first place.
Not only that, but also the PLC can continue running while the robot is powered down.
Yeah you're right, will need to have a external supply. so another question since those output ports are attached to 7.5A fuses does that mean in theory the power supply is cable of with standing that much current draw (obviously less than the 7.5A).
That would be a good assumption, but you don't know exactly how much is being used by the robot itself, so its hard to say how much is left available unless you measure it.
FanucRobotKid
Changed the title of the thread from “Can you use the 24VDC Output from an R30IB Controller to Power up a PLC and Some I/O Modules?” to “.”.
