YRC 1000 - H20DT - Palletizing Help
  • Maxx Dull
  • August 11, 2021 at 4:08 PM
  • Maxx Dull
    5
    I am looking for help on palletizing .
    Currently, I have 50 objects to stack. I can do layers of 10.
    I can stack them now, but was looking for a more efficient way to do it.
    Is there a way to create an origin point, (X,1,y1,z1) and then each layer just add a set +z value to add another layer, and just loop that. that way I don't have to create a new point or origin point for each layer.
  • 95devils
    230
    8
    1,934
    • August 11, 2021 at 4:39 PM
    Quote from Maxx Dull
    Sure, you can use a Position Variable and Shift on the amount and direction. Before your moves that you want to shift add a line that reads SFTON Pxxx. The Pxxx is a variable that has an address. Use an address that is not being used by the system, such as P050. When you want to move to a non-shifted position add the SFTOF.
    MOVJ
    MOVJ
    SFTON P050
    MOVL
    MOVL
    'end effector
    MOVL
    SFTOF
    After the layer is done you could add Pxxx Pxxx. The second position variable has the amount in the Z-element that is the height of the object.
    ADD P050 P051 P051 has a Z-value of the object height.
    Another way is to have a layer counter instead of the ADD. After a layer is completed INC the layer counter and multiply.
    INC I000
    SET D050 (I000-1)*Object height
    SETE P050 (3) D050
    After the pallet is complete re-zero the shift amount with SUB P050 P050.
    You could also program all the positions calculated out.
    The wonderful world of programming, 10,000 ways to do the same thing.
    All address are for example only. You would need to use something that is not being used already.
  • Maxx Dull
    5
    • August 11, 2021 at 5:10 PM
    Awesome, thanks. Definitely multiple ways of doing different things.
    Do you have any ideas on how to start from the middle of a layer?
    Like, if I was palletizing 10 parts per layer, and got to the 3rd layer on part 5, and stopped the program for some reason. How could I cycle the robot to start from the 3rd layer part 6?
  • 95devils
    230
    8
    1,934
    • August 11, 2021 at 5:49 PM
    What I do is have a label for a position on the layer.
    JUMP *1 IF B010=1
    JUMP *2 IF B010=2
    PAUSE
    'Invalid position.
    JUMP *OUT
    *1
    SFTON P050
    'approach point
    MOVJ C00002 VJ=50.00
    'drop point
    MOVL C00003 V=400.0 PL=0
    CALL JOB:OPENGRIP
    TIMER T=0.50
    'approach point
    MOVL C00004 V=1600.0
    'increment part counter
    INC B010
    JUMP *PLACED
    *2
    SFTON P050
    'approach point
    MOVJ C00005 VJ=50.00
    'drop point
    MOVL C00006 V=400.0 PL=0
    CALL JOB:OPENGRIP
    TIMER T=0.50
    'approach point
    MOVL C00007 V=1600.0
    INC B010
    JUMP *PLACED
    *PLACED
    SFTOF
    Off of this I can start anywhere on the pallet with a layer counter and position on layer counter.
  • ljuba
    33
    5
    281
    • August 11, 2021 at 10:29 PM
    well I think that the best way to do the palletizing is calculating the position.
    You can have a macro that would do the math, according the arguments used to call the macro.
    Like, call macro arg1 layer, arg2 part count
    With that you calculate the position. No mess with jumping up and down.
  • TSGIR
    81
    713
    • August 11, 2021 at 10:45 PM
    The other way is use Pallet Solver software, it calculate all of positions by software and give to the robot but it is expensive solution.
  • ljuba
    33
    5
    281
    • August 12, 2021 at 12:11 AM
    Quote from TSGIR
    Pretty expensive solution!!! 🤣😂🤣😂🤣😂
  • 95devils
    230
    8
    1,934
    • August 12, 2021 at 1:14 AM
    Quote from ljuba
    Agreed. The questions led me to believe the OP doesn’t have a lot of experience. Learn the basics then move to more complex programming.
  • ljuba
    33
    5
    281
    • August 12, 2021 at 1:27 AM
    Quote from 95devils
    a think that there is even a thread here, talking about paletizing, and mentioned 3 or 4 different ways to do so.
  • Maxx Dull
    5
    • August 23, 2021 at 4:15 PM
    Thanks everyone for the help. Think I've come to a solution
  • palletizing
  • Palletizing Function
