DX200 Communication
  • Gurtej Singh
  • August 11, 2021 at 11:46 AM
  • Gurtej Singh
    29
    Hi everyone,
    I am a student and trying to learn how to communicate with DX200 in real-time, I am trying to receive UDP signals in DX200 and interpret them to control MOTOMANrobot later. But the first part is how to receive the external signals and second part is how to interpret it to use data to control robot. I have tried checking M registers but couldn't find anything there. Please help !!
    BR
    Edited once, last by Gurtej Singh (August 11, 2021 at 1:20 PM).
  • Go to Best Answer
  • TSGIR
    81
    713
    • August 11, 2021 at 7:10 PM
    Can you tell what device can you connect to the DX200?
    PLC, PC , HMI and ...
  • el_dk
    10
    • August 12, 2021 at 11:16 AM
    Are you trying to control the robot using physical I/O signals? Ethernet commands? FieldBus protocol?
    There is an Option Package to communicate with the controller using TCP. A bit complicated, if you are not familiar with "regular" programming, but depends on how advanced you want to get.
  • Gurtej Singh
    29
    • August 12, 2021 at 3:18 PM
    Quote from el_dk
    Hi el_dk,
    I will have a brief overview here, I am using a PC, Speedgoat baseline and DX200 controller from YASKAWA. The main purpose is to deploy a Simulink code from PC to Speedgoat and from speedgoat to Dx200 (connected to CN104 via ethernet) I have realtime UDP communication protocol between speedgoat to DX200 and they are able to ping each other. But when I try to send some data from simulink to DX200:
    1) Which port should I send data to ?
    2) How to see the data is received by DX200?
    I am also willing to use MOTOplus to make it easier to fetch data recieved from speedgoat.
    I want to control MOTOMANRobot using simulink code in communication with real time feedback from cameras (Welding and hyperspectral)
    Can you please tell a bit more about this option package and where can I find it ?
    Thank you so much for replying
    Gurtej Singh:smiling_face:
  • Gurtej Singh
    29
    • August 12, 2021 at 3:20 PM
    Quote from TSGIR
    Quote from Gurtej Singh
    Hi el_dk,
    Hi TSGIR,
    I am connecting Speedgoat baseline which is a real time target machine used for running real time simulations and I am connecting it to CN104 port of Dx200
    Gurtej Singh :smiling_face:
  • TSGIR
    81
    713
    • August 12, 2021 at 3:30 PM
    For send/ receive data from Ethernet port via PC, please see the Ethernet manual for DX200, in that manual explain how you must create a string of data for send / receive data between PC and DX200.
    For your other needs for Motoplus function, you must buy it from Yaskawa, it need a software for create your program and export a *.out file from it and load on the controller, for real time data in Motoplus, you must use "ctrl sensor" example in the manual, with this function you can send any data to robot in real time and robot will move according to value that you give in this function.
    This function use for send data in real time to robot.
  • Gurtej Singh
    29
    • August 12, 2021 at 5:23 PM
    Quote from TSGIR
    Very big thanks for replying.!!
    Yes, I found the structure of the data in the manual named "DX200 OPTIONS INSTRUCTIONS FOR ETHERNET FUNCTION", I am going through it .. but do u know any detailed similar example where they do the send/recieve from PC via Ethernet Port..?
    I have Motoplus from yaskawa and I will look through "ctrl sensor" and i will update you how it goes..!!
    Also, one problem is when I try sending data to DX200 from SpeedGoat (in Simulink format) it asks for a port number.. do u know about port number for UDP.. i was trying with 11000 but its wrong
  • TSGIR
    81
    713
    • August 12, 2021 at 7:20 PM
    Check with port number between 10000 to 10008.
  • Gurtej Singh
    29
    • August 13, 2021 at 11:15 AM
    Quote from TSGIR
    I tried all of them but it says "Unable to connect to remote host: Connection refused" on QNX and it says following in MATLAB.
  • TSGIR
    81
    713
    • August 14, 2021 at 6:07 PM
    • Best Answer
    try with port number 80, 2005 and 2006.
  • Gurtej Singh
    29
    • August 15, 2021 at 9:00 PM
    • #11
    Quote from TSGIR
    Thank you TSGIR, I think port number 80 works..!!!
  • TSGIR
    81
    713
    • August 15, 2021 at 10:14 PM
    • #12
    Your welcome, please share your experience and example that you are working in this post, maybe some other people need use it in the future.
  • loschi
    • March 14, 2024 at 2:26 PM
    • #13
    Hi Gurtej
    I'm also a student, could you explain, step by step, how you created the communication between the pendant and the PC to send commands to the robot?
Similar Threads
  • dx200 cn103(serial port)(RS232C) signal voltage
    • ofc11
    • June 14, 2021 at 9:18 AM
    • Yaskawa Motoman Robot Forum
  • Communication between Kemppi and DX200
    • TSGIR
    • July 29, 2019 at 1:05 PM
  • yaskawa dx200 and sks serial communication is not stable
    • nilpatil
    • December 7, 2018 at 7:41 AM
  • PLC VIPA connect to DX200
    • robotik
    • May 22, 2018 at 8:46 AM
  • Controller communication port For dx200
    • omran_1431
    • February 28, 2018 at 3:48 PM
  • How to use udp to read/write YASKAWA robot in dx200 controller?
    • acer1204
    • January 26, 2018 at 8:53 AM
  • COMMUNICATION WITH SERVO ROBOT! DX200 MH12
    • MikeGiantMtl
    • July 3, 2017 at 6:04 PM
  • Yaskawa dx200
