First off, I am new at this.
We have Fanuc M-900iB/280 purchased with Ethernet/IP option, EOAT has master IO-Link ethernet/ip reading analog sensors through a converter connected to the IO-Link module, also communicates to line plc through Ethernet. As I understand, there are 2 Ethernet ports in robot controller can be configured as scanner and adapter, I will configure one port as scanner for EOAT, other port as adapter for PLC.
My questions are:
Which ports to configure as scanner?
Do I need anything else in robot controller side to receive analog values?
Do I need EDS files for EOAT?
Do I need EDS files for PLC to communicate to robot controller?
Thanks for your advice.
