I am having a weird problem with my connector on my inputs. I am on a 30iB plus mate controller, and a 50 pin connector and wired exactly to the pin out. I cannot get any of the inputs to work, i have setup my inputs on rack 48 slot 1 start 1 and i have confirmed that i am getting 24V to input 1, yet it does not turn on. I have a similar cell at our shop and thought maybe the wiring was wrong on the connector but when i plugged that same cable into that robot and put 24V to the input 1, it turns on and works fine. Is there some setting or configuration i am forgetting to set in the robot? its been a while since i set up the one in our shop and don't recall having any issues or if i configured the robot to make it work.
Honda Connector
Kyle0588 -
August 3, 2021 at 4:10 PM -
... but when i plugged that same cable into that robot ...
which same cable to which robot?
Did you try the other cable to the other robot?
Normally you don't have more to do than setting rack, slot and start. Is it showing blue 'ACTIVE' state in the configruation of the I/O?
In that cases most time the ground or power supply is not connected.
Sorry for the confusion. The honda connector that I have in the field (which was not turning on any inputs) i brought back to our shop and plugged it into another robot (same type and controller) and supplied 24V to input 1 and it worked here.
I cannot figure out what the issue is. I am bashing my head over it.
What about the ground connection on your connector?
Where did the 24V come from? Once in the field and once in the shop.
Not sure with the R-30s, but I know the R-J3s have a jumper that determines whether i/o is sinking or sourcing. Admittedly a longshot, but...
I'm having the same problem did you find any fix?
