I have an R-2000 iC 210F robot. I established a connection between roboguide and the robot controller.
The question is how to create a backup of the robot via roboguide?
Do you want to create a Roboguide cell from the robot? Or do you want to take a backup?
On the virtual controller back up the robot how you would normally ( I always select MC) then go to "My workcells" folder, open whichever project it is, open "Robot1" then open MC folder and the backup will be in there
I want to take a backup from the real not virtual controller via roboguide
I don't think you can take a backup of a robot using Roboguide.
Many people use the One Robotics tools to take a backup over the network connection.
You can backup using any FTP client.
You can backup a real robot directly from Roboguide.
Assuming you have the real robot setup in your robot neighborhood:
If you need to add your robot to the robot neighborhood, Open the robot neighborhood from your start menu. And fill in the information for a new entry in your group.
