How to copy mastering offset from one tool to another?
  • Hi,
    Let say we have a tool changer and 3 tools but they are pretty the same (same weight, shape, etc.). On KR C2 we had a file with mastering offset with extension .cal in C > krc > roboter > ir_spec and we could just copy and paste mastering. Is there something like this on KR C4/C5? Mastering each tool is time-consuming and I would prefer copy if tools are almost the same.
    thanks in advance
  • I have seen this in KRC4 KSS 8.3 and 8.5. First, you go to menu>start up> robot data and select save RDC data to make sure the file will be available. Then you can navigate to C:\KRC\ROBOTER\RDC\xxxx.cal where xxx is the serial number.
