KRL Variable Assigned to an attribute in a STRUC
  • jonathan.davis
  • July 30, 2021 at 5:41 PM
  • jonathan.davis
    5
    I'm having an issue creating an array of STRUC's I'd like to loop through and perform the same operation on.
    Right now, I have a STRUC and a value using that type.
    GLOBAL STRUC PARAM_TYP REAL current, past, CHAR name[25]
    DECL GLOBAL PARAM_TYP _paramArray[100]
    _paramArray[1] = {current 2.0, past 2.0, name[] "_offsetE1"}
    _paramArray[2] = {current _offsetE1, past 2.0, name[] "_offsetE1"}
    Param 1 works but param 2 shows the error "INTEGER, REAL or CHARACTER constant expected"
    Am I to understand that you cannot assign values in STRUC's by reference to another variable?
    Edited once, last by jonathan.davis (July 30, 2021 at 5:48 PM).
    SkyeFire
    1,038
    9,373
    • July 30, 2021 at 7:56 PM
    • Best Answer
    Correct. You can't have more than one layer of abstraction, so to speak. No "indirect addressing," to put it another way. Each member of a STRUC must be set to a literal value, not "pointed" to another variable.
    So, in your .DAT file array, you would need to assign some literal initial value. Then, in your executable code, assign by:
    _ParamArray[2].current = _offsetE1
  • jonathan.davis
    5
    • July 30, 2021 at 8:40 PM
    But there'd be no way to keep it up to date with whatever value that _offsetE1 gets adjusted to would there be without explicitly running that code every time?
    Thanks for your help
    Edited once, last by jonathan.davis (July 30, 2021 at 8:57 PM).
  • hermann
    403
    2,593
    • August 1, 2021 at 9:44 AM
    If you need two variables that always have the same value, why using two variables instead of one?
    SkyeFire
    1,038
    9,373
    • August 1, 2021 at 10:42 PM
    Quote from jonathan.davis
    Correct. You would need to run the executable "update code" periodically, or as an event-driven action. Depending on your specific needs. There's no way to "link" the two variables together dynamically, aside from adding the update code to an SPS background task.
  • KRC 4. KSS 8.3.7. KR 6-2. DNet
