I have a R30iB Plus on my hands,
I want to do the following,
I want to have easy editable constant numbers in the program to allow me to edit the position of clips inserts,
For example I want to move left or right by .5 mm and I can change the constant from 25.5, Problem sorted.
I ran the code and it work somewhat,
The only problem is that PR[10] always seems to use Tool 0 or world co-ordinates,
I have tried every tool function I could see and always it still moves wrong.
The tool is relatively simple only a 250 mm offset on the z axis.
But when I want to insert the clip I need the W axis to be about -6
I have defined a second tool and can jog in this plane no problem but when I run the program below it still moves in original tool or world co-ord
Literally tried the last 3 hours and it just wont work, I am out of idea from the menus and other forum posts nothing I do seems to work
Thanks in advance
! Move Left Right
UTool_Num = 2
Pr[10] = LPOS
PR[10] = PR[10,1] + 25
L PR[10] 100mm Fine
! Move Forward Back
Pr[10] = LPOS
PR[10] = PR[10,2] + 25
L PR[10] 100mm Fine
! Move Up / Down
Pr[10] = LPOS
L PR[10] 100mm Fi
