Different Position Joint
  • Botty
  • July 29, 2021 at 10:15 AM
  • Botty
    23
    Hello!
    I'm trying to create a random movement in one of them and copy paste the program to the other one.
    So I decided to make the setup of the User Frame for two identical robots (hence with the same Frame) separately, but when pasted the point from Robot 1 to Robot 2, the positions do not match.
    After this, I copied the Frame values from Robot 1 into Robot 2, copied the position of the point as well, and they still aren't matching.
    I justed cheked the POSN values to make them match, and with the same position values, they do not look the same: Robot 1 is quite up above and Robot 2 is below and with the tool slightly twisted.
    Why is this happening? It is maybe because an error during the first setup of the robot?
    **note that both positions have the same UF:1 and UT:1
    Thankyou :smiling_face:
  • Go to Best Answer
  • HawkME
    570
    3,270
    • July 29, 2021 at 3:00 PM
    Are the robots the same, are you sure that UF and UT are the same and selected, is the motion config string the same? Are you starting from the same position? Are you using joint or linear motion?
    Show pictures.
  • Botty
    23
    • July 29, 2021 at 5:04 PM
    Hi!
    I manage to find the problem... I needed to masterize the robot again. The zero position was not the same on both of them! Thankyou HawkME
    Btw, how can I change the configuration (NBD 0 0 0 to NUT 0 0 0) of an already-set frame?
  • pdl
    272
    1,549
    • July 29, 2021 at 5:09 PM
    • Best Answer
    The configuration of a frame does not matter.
  • Botty
    23
    • July 30, 2021 at 11:39 AM
    Okey! I'll take this into account. Thankyou pdl
Similar Threads
  • Making decisions based on current robot position
    • D_DeVanney
    • December 3, 2018 at 8:38 PM
    • Fanuc Robot Forum
  • In singularity
    • m3pisnik
    • July 21, 2020 at 8:32 AM
    • Fanuc Robot Forum
  • pneumatic system
    • kingofjong
    • June 10, 2020 at 1:12 AM
    • General Robotics Discussions - everything but NO Industrial Robots
  • TCP Six Point (xy) Method
    • Idunno
    • December 5, 2019 at 6:20 PM
    • Fanuc Robot Forum
  • Robot Issue: Kuka KR 150.2
    • technician820
    • March 29, 2019 at 9:47 PM
    • KUKA Robot Forum
  • World Coordinates Error cannot move linear.
    • AML1994
    • July 29, 2018 at 12:50 PM
    • Fanuc Robot Forum
  • Is there a way to force ABB to rotate clockwise with respect to axis 6?
    • John11
    • January 13, 2018 at 4:42 PM
    • ABB Robot Forum
  • position modfying
  • position
  • joint
  • move
  • Axis
