Workbench opening safety issue.
  • First i would like to say HELLO to all of You, as it is my first post here.
    I've got an problem with workbench for kuka iiwa.
    I started the new project, by downloading it from controler
    When i try to open safetyconfiguration i've got an error. "Could not open the editor: An unexpected exception was thrown."
    Details of this error looks as follow
    Do u guys have any ideas how to fix that?
    I didn't try to reinstall workbench, because it takes 2 days in my company to install anything...
    BR
    Krystian
  • Which version of Workbench/OS?
    Are you using Windows 10 on your PC?
    I have had a few issues with Sunrise.Workbench not running correctly when it was not installed properly. From my experience, a simple mistake made the whole software crush. e.g.:
    1. When installing, make sure the path is short. Also keep the names of the options short.
    2. Install as administrator
  • Thanks for Your replay.
    The problem was caused by wrong workbench version. I tought it is compatible backwards but it isnt.
    I found correct version, same as my OS and it works fine.
