EthernetKRL Real time Variables monitoring
  • RainerFord
  • July 26, 2021 at 5:19 PM
  • RainerFord
    27
    Hello
    We have a KRC4 controller with an EthernetKRL option.
    The main objective we want to achieve is constant real time monitoring of some variables, which will be send to the robot from server via EthernetKRL.
    I tried to make some simple progs, which have some kind of while loop inside. But I faced the problem: The program works only a limited time because of EKI01280 and EKI01792 (Limit of memory element reached) Errors. The problem with first error I solved with EKI_Lock command, but is there a way to solve a problem with a second error? The manual says to increase buffer size, but as I see, it will be a bad solution, as the program will work a little bit longer, but It will be stopped by an error anyway...
    panic mode
    1,267
    13,037
    • July 26, 2021 at 10:15 PM
    you may want to elaborate... i would suggest to check pinned topic READ FIRST.
    for example you posted no code, mentioned no software versions etc.
  • RainerFord
    27
    • July 27, 2021 at 9:25 AM
    Yep. My Bad. Software version is 8.5.8
    And also, the EKI_Lock didn't solved the problem as it causes EKI00015 (Access to empty element memory) error... So I added ClearBuffer instruction at the end of the cycle as I don't need buffer anyway. I don't know will it help or not as I still testing the program. But it seems OK right now.
    The code For program is
    &ACCESS RVP
    &REL 67
    &PARAM EDITMASK = *
    &PARAM TEMPLATE = C:\KRC\Roboter\Template\ExpertVorgabe
    &PARAM DISKPATH = KRC:\R1\test
    DEF XmlTransmit()
      INT TAC, TA[6]
      DECL EKI_STATUS RET
      REAL BX, BY, BZ, BA, BB, BC
      BOOL ConMove, Lube, STP, RSENS
    ;FOLD INI
      ;FOLD BASISTECH INI
      BAS (#INITMOV,0 )
      ;ENDFOLD (BASISTECH INI)
      ;FOLD USER INI
        ;Make your modifications here
      ;ENDFOLD (USER INI)
    ;ENDFOLD (INI)
    ;FOLD SPTP P1 Vel=100 % PDAT1 Tool[1]:Tool1 Base[0] ;%{PE}
    ;FOLD Parameters ;%{h}
    ;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.spline; Kuka.IsGlobalPoint=False; Kuka.PointName=P1; Kuka.BlendingEnabled=False; Kuka.MoveDataPtpName=PDAT1; Kuka.VelocityPtp=100; Kuka.VelocityFieldEnabled=True; Kuka.ColDetectFieldEnabled=True; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=SPTP
    ;ENDFOLD
    SPTP XP1 WITH $VEL_AXIS[1] = SVEL_JOINT(100.0), $TOOL = STOOL2(FP1), $BASE = SBASE(FP1.BASE_NO), $IPO_MODE = SIPO_MODE(FP1.IPO_FRAME), $LOAD = SLOAD(FP1.TOOL_NO), $ACC_AXIS[1] = SACC_JOINT(PPDAT1), $APO = SAPO_PTP(PPDAT1), $GEAR_JERK[1] = SGEAR_JERK(PPDAT1), $COLLMON_TOL_PRO[1] = USE_CM_PRO_VALUES(0)
    ;ENDFOLD
    RET=EKI_Init("Transmit")
    RET=EKI_Open("Transmit")
    BX=0
    BY=0
    BZ=0
    BA=0
    BB=0
    BC=0
    RSENS=FALSE
    ConMove=FALSE
    Lube=FALSE
    STP=FALSE
    REPEAT
    TAC=0
    FOR TAC=1 TO 6
    TA[TAC]=$MOT_TEMP[TAC]
    ENDFOR
    ;FOLD Write data
      ; Write Temps
      RET=EKI_SetInt("Transmit","Robot/ReducersTemp/Temp1", TA[1])
      RET=EKI_SetInt("Transmit","Robot/ReducersTemp/Temp2", TA[2])
      RET=EKI_SetInt("Transmit","Robot/ReducersTemp/Temp3", TA[3])
      RET=EKI_SetInt("Transmit","Robot/ReducersTemp/Temp4", TA[4])
      RET=EKI_SetInt("Transmit","Robot/ReducersTemp/Temp5", TA[5])
      RET=EKI_SetInt("Transmit","Robot/ReducersTemp/Temp6", TA[6])
      ; Write Bools
      RET=EKI_SetBool("Transmit","Robot/Taking",RSENS)
    ;ENDFOLD (Write data)
    ;FOLD Send data to external program
      RET = EKI_Send("Transmit","Robot")
      WAIT SEC 1
    ;ENDFOLD (Send data to external program)
    ;FOLD Get data
       ;Bag Coordinates
      RET=EKI_GetReal("Transmit","TRANS/Pos/BagCoordX",BX)
      RET=EKI_GetReal("Transmit","TRANS/Pos/BagCoordY",BY)
     RET=EKI_GetReal("Transmit","TRANS/Pos/BagCoordZ",BZ)
      RET=EKI_GetReal("Transmit","TRANS/Pos/BagCoordA",BA)
     RET=EKI_GetReal("Transmit","TRANS/Pos/BagCoordB",BB)
      RET=EKI_GetReal("Transmit","TRANS/Pos/BagCoordC",BC)
       ;Booleans
      RET=EKI_GetBool("Transmit","TRANS/ConvBool" ,ConMove)
      RET=EKI_GetBool("Transmit","TRANS/NeedLube" ,Lube)
      RET=EKI_GetBool("Transmit","TRANS/STOP" ,STP)
    ;ENDFOLD (Get data)
    RET=EKI_ClearBuffer("Transmit","TRANS")
    WAIT SEC 1
    ;ENDFOLD
    UNTIL $IN[205]==TRUE
    RET=EKI_Close("Transmit")
    RET=EKI_Clear("Transmit")
    END
    And the Config file is
    <ETHERNETKRL>
        <CONFIGURATION>
            <EXTERNAL>
                <IP>192.168.10.44</IP>
                <PORT>60000</PORT>
            </EXTERNAL>
        </CONFIGURATION>
        <RECEIVE>
            <XML>
                <ELEMENT Tag="TRANS/Pos/BagCoordX" Type="REAL"/>
                <ELEMENT Tag="TRANS/Pos/BagCoordY" Type="REAL"/>
                <ELEMENT Tag="TRANS/Pos/BagCoordZ" Type="REAL"/>
                <ELEMENT Tag="TRANS/Pos/BagCoordA" Type="REAL"/>
                <ELEMENT Tag="TRANS/Pos/BagCoordB" Type="REAL"/>
                <ELEMENT Tag="TRANS/Pos/BagCoordC" Type="REAL"/>
                <ELEMENT Tag="TRANS/ConvBool" Type="BOOL"/>
                <ELEMENT Tag="TRANS/NeedLube" Type="BOOL"/>
                <ELEMENT Tag="TRANS/STOP" Type="BOOL"/>
            </XML>
        </RECEIVE>
        <SEND>
            <XML>
                <ELEMENT Tag="Robot/ReducersTemp/Temp1"/>
                <ELEMENT Tag="Robot/ReducersTemp/Temp2"/>
                <ELEMENT Tag="Robot/ReducersTemp/Temp3"/>
                <ELEMENT Tag="Robot/ReducersTemp/Temp4"/>
                <ELEMENT Tag="Robot/ReducersTemp/Temp5"/>
                <ELEMENT Tag="Robot/ReducersTemp/Temp6"/>
                <ELEMENT Tag="Robot/Taking"/>
            </XML>
        </SEND>
    </ETHERNETKRL>
    Edited once, last by RainerFord (July 27, 2021 at 9:43 AM).
