Hello All ,
does anybody have GSDML file for CP1616 (6GK1161-6AA01 V2.1) card to share please?
thanks in advance
Hello All ,
thanks in advance
You have to create it by yourself. The content depends on the amount of i/O you need.
Search for your product, you will find a description how to build it with Tia portal on the Siemens support site.
Thanks for reply hermann
But i haven't TIA portal, i have NCM PC Manager ,is there any other way to access GSDML file for this card?
Other question, where is the cp1616 installed, what is connected to it?
kuka KRC2 Ed.05+cp1616+ET200s with I/O cards
I have installed CP card on KUKA PC,and i want to download my configuration to it but NCM PC Manager (V5.4) just have CP1616 V2.0
Now i want to install GSDML of my own card (6GK1161-6AA01)
Do you have the profinet manual?
If not: KRC2 manuals for KSS Version 5.2
In that manual everything is described.
I don't have problem from KRC side
.. NCM PC Manager (V5.4)...
Which exact version? May be you need an update to a newer SP or hotfix. Think it is not possible to include the newer Cp1616 via GSDML file. There exist no GSDML file for Cp1616.
There exist at least a version 5.5.4 sp1. So may be looking for that version will do the job. The problem may be that NCM manager isn't supported as standalone any more. It is part of the bigger packages like step7, Tia, or winCC.
Search on Siemens site.
Excerpt from manual, from an above posted link.
As you can see, reading the manual can help.
