Transmission of system variables...STEU\Mada\$machine.dat
  • pfuser
  • July 23, 2021 at 1:39 PM
  • pfuser
    59
    Hello.
    Robotic programming.
    I am learning about system variables.
    For example, I want to pass some robot system variables to a other controller via Profinet.
    I have to modify the file KRC:\STEU\Mada\$machine.dat (SIGNAL $IN_HOME1 $OUT[1]
    In the mapping pass, connect $OUT[1] to the desired Output.
    Do I understand correctly?
    Or can I create my own file, which will then overwrite this value?
    Thanks.
    Images
      • 384.57 kB
      • 1,614 × 757
      • 48
    panic mode
    1,278
    13,079
    • July 23, 2021 at 2:31 PM
    yes you are thinking correctly. map I/O in WoV, then assign system signals to I/Os of your choice.
    many signals can be assigned through HMI by editing AutoExternal interface. some can be only modified by editing file. but careful with manually editing MADA...
    you can create own DAT file and declare signals there. this is practical for deploying (keep things in one place rather than edit bunch of files)
  • pfuser
    59
    • July 23, 2021 at 2:51 PM
    Quote from panic mode
    Thank you.
    And the name (mashine.dat) of the file and the directory where the file will be located?
    Can you give me a hint, please?
    panic mode
    1,278
    13,079
    • July 23, 2021 at 2:58 PM
    there are two MADA sets. "MADA" is short for "Machine Data"
    manipulator MADA is set of files in KRC:\R1\MADA
    controller MADA is set of files in KRC:\STEU\MADA
    long time ago it was assumed that one controller would control several manipulators but that prediction was wrong so you will not see folders for R2, R3 etc.
  • pfuser
    59
    • July 23, 2021 at 3:08 PM
    Thank you
Similar Threads
  • RS232 comms to the XCP01 port on XRC /UP6 Robot
    • lostcontrol
    • August 25, 2020 at 8:05 PM
    • Yaskawa Motoman Robot Forum
  • Robot Signals Help?
    • n0909
    • March 18, 2018 at 10:16 PM
    • KUKA Robot Forum
