KSS 8.3.14, KRC4
I have been using a program to start and stop a trace recording (see pdf, apologies but could only upload one document). Today I changed the $TRACE.NAME[] variable and now I get the message and the .src and .dat files are no longer visible in the directory from the message. I have changed the trace name multiple times in the past without trouble, however, this is the first time I have recorded multiple traces without exporting old ones. The other programs are working fine, it is only this one, nevertheless I would like to find the problem so that it doesn't persist.
I have exported the traces and deleted them then tried a cold start but it didn't help.
Any help would be greatly appreciated.
NOTE: The bool DAQ_VAR is a global variable in global.dat that is modified externally by JOpenShowVar.
Thank you
