Input transfer to outpus
  • Serpantinas
  • July 14, 2021 at 11:56 AM
  • Serpantinas
    81
    is there a nicer way to do this, I need to make about 50 Inputs to turn on outputs (KSS8.6)
    IF $IN[1]==TRUE THEN
     $OUT[1]=TRUE
    ELSE
     $OUT[1]=FALSE
    ENDIF
    IF $IN[2]==TRUE THEN
     $OUT[2]=TRUE
    ELSE
     $OUT[2]=FALSE
    ENDIF
    IF $IN[3]==TRUE THEN
     $OUT[3]=TRUE
    ELSE
     $OUT[3]=FALSE
    ENDIF
  • Mentat
    61
    5
    243
    • July 14, 2021 at 12:03 PM
    for i = 1 to 3
        $out[i] = $in[i]
    endfor
    Not sure what the ifs are doing in your example; you need the output value to be the same as corresponding input value- just assign it.
  • Serpantinas
    81
    • July 14, 2021 at 12:13 PM
    I remember it didn't work like this, but maybe it was trying this with positions.
    I'll give it a try, thanks
  • panic mode
    1,267
    13,033
    • July 14, 2021 at 7:00 PM
    if you run into an issue, probably it was output that is assigned one of system functions. those are identified in I/O list by mark "SYS". such functions can be freely remapped to any other I/O but only some can be changed through UI without opening and editing files.
