Hi all,
I am using Modbus TCP and SNPX option with FANUC. I am using pymodbus.
When I am working with Roboguide, I can read and write registers, DO[x], R[x] and UI[x].
However, when I tried to connect to actual robotic arm, using the same script it did not work
request = client.read_holding_registers(start_address,4,unit=UNIT)
vals = request.registers
print(vals)
I received this when I did not catch the exception.
AttributeError: 'ExceptionResponse' object has no attribute 'registers'
and, when I did catch
('Modbus Error:', <pymodbus.pdu.ExceptionResponse object at 0x7fb4b8901d50>)
on the Teach Pendant, I see "Modbus TCP Server Error."
but, the pymodbus says the connection is successful, however, as soon as the reading or writing, it gives immediately the error,
AttributeError: 'ExceptionResponse' object has no attribute 'registers'(on the PC side)
"Modbus TCP Server Error." (on TP)
please, can somebody help in that.
thanks,
Zahid
