I have wired in a solenoid into pins 31 (output#1) on the XGPIO connector. When I force O1 On using the teach pendent my solenoid does not activate. I tried measuring the connection on the back of the robot controller to make sure I did not wire anything in incorrectly. I am unable to get any of the output pins to turn on 24V when forcing on outputs at the teach pendent. The supply power pins all show the correct 24V.
I checked AUX608, and the DIO is set to O1-O16. I have been forcing outputs by setting one of the monitors on the teach pendent to Output Signal and then using the On and Off hardkeys to turn signals on and off. I am looking for advice on what I might be doing wrong. I am not sure if I am just flipping the wrong outputs or if something is setup incorrectly. Any help is appreciated. Thanks!
