Hi guys,
Is possible to use profinet board to create a communication between robots without external PLC(Like Siemens). Using profinet like EDG robot.
Hi guys,
Any help please?
Yes it should be possible, if the robots have profinet option. Why shouldn't?
Because I can't find the right configuration to allow the communication.
I set ip on channel 2.
Connect robots via Profinet. Set rack 102 but doesn't work.
Get error Chnl 2 slot 1 idle.
Controller versions?
OS version?
Options?
.. set ip on channel 2.
Which channel 2? Profinet setup is not done in communication setup. Normally you need a special profinet board, profinet option, Tia portal from Siemens and some configuration files.
Just an annotation:
You have a specific problem, because you already tried to connect two robots via profinet. But you are asking a general question. In such cases you should tell us that you already tried, and what exact you already tried. Makes things much easier.
OS version?
Options?
R30IB plus
Os version:
9.30
Option:
A05B-2600-J076
PROFINET BOARD
LX05B-2600-J083
MOLEX PROFINET DAUGHTER BOARD
A05B-2600-R834
PROFINET MOLEX DUAL CHANNEL
OS version?
Options?Which channel 2? Profinet setup is not done in communication setup. Normally you need a special profinet board, profinet option, Tia portal from Siemens and some configuration files.
Just an annotation:
Thanks for reply. I'm trying to communicate I/o signals through Profinet connection.
Robots has option I've wrote below.
At the moment I don't need an external plc like Siemens. I need only create a feedback between robots like EGD IO function.
I setup Profinet channel with a common IP address:
192.168.100.10 ( for robot 1)
192.168.100.11 ( for robot 2)
Set-up DI/DO 201-301 on rack 102 ( same two robots)
Reboot the controller but communication doesn't work and I get this error on channel 2.
.. I setup Profinet channel with a common IP address: ..
Which channels? You have to configure channel 1 on the controller robot and channel 2 on the device robot.
Did You use the PFN-CT (profinet configuration tool)? You have to use that to configure your controller robot. Therefore you have to get the gsdml file for the fanuc robot and import it into PFN-CT. ....
But these things are described in detail in the documentation B-82864EN_05. rtfm
EDIT: And by the way: what is:
EDG robot.
EGD IO function.
Never heard about that.
