IF Statement Syntax
  • Hello,
    I am using an E controller and trying to call subroutines from my master program using conditional if statements and individual inputs from a Mitsubishi PLC. However I haven't been able to sort out the correct syntax to get it working correctly.
    This is what I have so far:
    HOME
    CALL reset_io
    IF 13 THEN; TIP EXCHANGE
    CALL tip_exchange
    GOTO 999
    END
    IF 17 THEN; TIP DRESS
    CALL tip_dress
    GOTO 999
    END
    IF 33 THEN; Call RH Part
    CALL rh_part
    GOTO 999
    END
    IF 34 THEN; Call LH Part
    CALL lh_part
    GOTO 999
    END
    999
    HOME
    CALL reset_io
    GOTO 1
    The controller accepts a number of different configurations including
    IF 33==ON THEN; Call RH Part
    CALL rh_part
    GOTO 999
    END
    However the robot will not enter the above routine when input 33 is in fact turned on.
    Any feedback is greatly appreciated, its my first time working with a Kawasaki robot.
    Cheers,
  • I would study the IF statement in the AS Manual, and also the correct input and output numerical references the Kawasaki uses this will highlight your syntax issues.
    The key here is you are not telling the controller to evaluate the state of a SIGNAL or using the correct numerical references to distinguish between inputs and outputs.
    There are many variations to argument evaluations when it comes to SIGNALS, so you can pick your preferred flavours.
    Output 1 for example:
    IF SIG(1) THEN
    END
    IF SIG(-1) THEN
    END
    IF NOT SIG(1) THEN
    END
    IF (SIG(1)==TRUE) THEN
    END
    IF (SIG(1)==FALSE) THEN
    END
    Input 1 for example:
    IF SIG(1001) THEN
    END
    IF SIG(-1001) THEN
    END
    IF NOT SIG(1001) THEN
    END
    IF (SIG(1001)==TRUE) THEN
    END
    IF (SIG(1001)==FALSE) THEN
    END
    As for myself when scanning my code I prefer the following flavours as they are easier to distinguish:
    END
    END
  • Thank you for your input Kwakisaki, I believe I have found the error in my syntax.
    Where do I set the master job? or in other words, id like to set my main job to start every time the robot is started.
    Edit- I found an existing post of starting a master job using pg0, RPS ON and pulsing the program reset input. I will be trying it out sometime today.
    Edited once, last by Shearzy ().
