In near future I want to create some milled parts using cam software and fanuc robot. Any of those programs uses hundreds or thousands of points. After developing many different parts there will be hundreds of different programs, so it will take lots of memory.
And there my question appears - how to deal with memory? I think fanuc robot itself can't provide such a big space to allocatate this.
I have read about using usb flash stick or ethernet port.
Can someone explain me how would it work with both of them?
-Do I have every single time load NEW program from usb and start it from program select or can I just start it via connected memory storage?
-If i run out of memory because of loaded programs do I have to manually delete some programs or can I set some kind of override?
-With ethernet - how do I load (transfer) program, do I have to use roboguide or other app for that? It is bascily a file so there is no need (I think) to import it and then transfer via RG
-Then again I guess I will have to delete some programs, can I load programs directly through teach pendant? Like it would choose a program from set directory on PC
-What addons (options) for robot should I have to run this?
I would appreciate any other thoughts
