Fanuc m710ic and elektrical cabilet
  • Hello.
    I have a robot Fanuc M-710iC/50 and elektrical cabilet (R30iA) from robot Fanuc m20ia. Can I connect this robot to this elektrical cabilet?
  • According to the inside of the controller, the answear is yes - the servoamplifier is the same, rest is the same too. But as far as I've checked I thing there's a problem with RCC cables - they're different.
  • The M-20 controller typically comes with a 3KVA transformer and the M710 comes with a 7.5KVA. So, I would not use that controller unless you can find the transformer part number and confirm that it has a high enough rating.
