Ask for instructions
  • User-RB
  • June 15, 2021 at 8:35 PM
  • User-RB
    16
    hello guys,
    I'm using a fanuc robot R-2000iB
    In milling operations ,so when I try to make a linear movement from A to B the robot moves in linear path but the spindle get inclined or declined so I have to fix the spindle level everytime.
    My question is how to make a linear movement in a horizontal level with the same height in each point A and B.
    I would appreciate any help.
  • mosbe
    52
    • June 15, 2021 at 9:17 PM
    In point choose you should pick Linear movement marked as L, it should always keep straight line from A to B
    But I guess you already know it and something other is a cause. Did it fix your problem?
  • User-RB
    16
    • June 15, 2021 at 9:58 PM
    thank you for your time sir, yes I use linear movement as you said "L" the robot moves In a linear line true, but the spindle gets inclined or declined it doesn't remain horizontal so I have to use a level gadget to fix the spindle before saving the point coordinates. Also when moving from A to B I have noticed a difference in 2 mm or 3 mm in height. Any suggestions ?
  • HawkME
    568
    3,268
    • June 15, 2021 at 10:04 PM
    Did you teach a user frame and tool frame?
    Have you verified your mastering is good?
  • User-RB
    16
    • June 15, 2021 at 10:52 PM
    actually I didn't do that, is that a thing we must do before teaching the robot ?
  • HawkME
    568
    3,268
    • June 16, 2021 at 12:24 AM
    It is if you want accuracy. There is plenty of info available on the forum and in the manual. Give it a try and post back if you have more questions.
  • User-RB
    16
    • June 16, 2021 at 1:40 AM
    I will, thank so much 🙏
  • hermann
    407
    2,615
    • June 16, 2021 at 7:00 AM
    You absolutely should have setup the tcp (user tool in Fanuc speach) at the tip of the grinder. Otherwise you won't get any good result.
  • User-RB
    16
    • June 16, 2021 at 9:33 AM
    Okay, I don't know how to do that but I'm gonna look for it on the internet and see. Thanks
Similar Threads
  • math functions inside TP program
    • zahid990170
    • June 9, 2021 at 2:37 PM
    • Fanuc Robot Forum
  • EIMOV instructions
    • Emre64
    • June 2, 2021 at 6:57 PM
    • Yaskawa Motoman Robot Forum
  • RobTarget not working properly
    • Egaleskay
    • May 20, 2021 at 5:55 PM
    • ABB Robot Forum
  • Arcof CIO address
    • Robottech
    • June 2, 2021 at 12:26 AM
  • Variable to adjust program pointer lookahead?
    • romanzo
    • November 10, 2019 at 10:00 PM
    • Fanuc Robot Forum
  • Spot Instructions in Keral
    • Akhil Mukundan
    • January 31, 2019 at 6:46 AM
    • Fanuc Robot Forum
  • Line instructions auto deleted?
    • MUNIACO
    • October 18, 2018 at 11:01 AM
    • Fanuc Robot Forum
  • Fanuc robot slows down at points when using register variable for speed?
    • failarmada
    • August 15, 2018 at 1:45 AM
    • Fanuc Robot Forum
  • Movement speed
    • MUNIACO
    • May 8, 2018 at 1:23 PM
    • Fanuc Robot Forum
  • fanuc robot
  • Fanuc 30ib
  • R-2000iB
