Hello
I loocking for a welding PIB Board
it is on a M2000 Robot controller with a LUA welding source
the board do not connected to the CAN BUS, the NS and MS LED is off
see the pic
Hello
see the pic
You should have 24V at the X2 CAN Bus connector on the PIB Module between pins X2-1 (0V) & X2-5 (+24V). That should at least get the MS turned ON.
That was what i have checked first. and Yes i have 24V , I have also remove the housing, but in the card i cant see any Fuse.
Think you also should plug in TB1, the upper left connector. There is included the power supply for the logic.
Yes. 28VAC between TB1-4 & TB1-5. If it's missing, check the 10W limiting resistor on the transformer primary.
The Card runs.
The elektrican found a small fuse.
i mean on the welding equioment
i self was not on site, they tould me torday morning
Thanks all for help
