  4. ABB Robot Forum
IRB 1600 IRC5, connection with PLC
  • schelle
  • June 14, 2021 at 1:12 PM
  • schelle
    32
    I got an used arc welding cell and have to modify it for our own production.
    At current configuration, plc is declared as master and IRC5 as a slave. From HMI is possible to start / stop, follow logs, chose auto / manual mode, chose program and so on.
    Considering habits at our plant, we want to disconnect plc, and use IRC5 on same way as other 3 robots at our plant - using teach pendant for steering the robot.
    Robot, beside others, have two tasks, task 0 and task 1, if I'm right, only for communication with plc.
    Now, how to remove remote mode for the robot and start to use it in local. We has to keep communication with welding power sources and other auxiliary equipment as well.
    Backup file enclosed.
    16-52494_Backup_20210519.zip
    BR/
    Schelle
  • robiman
    10
    116
    • June 15, 2021 at 9:17 AM
    first,you should verity the Option from both robot sytems
    check the ePlan and wiring of the cells, maybe you must modify it
    also check the welding systems maybe the communikation ist diffrent
    in summary is depend how much expenditure you want invest
    http://www.hw-automation.de<br />Teach Pendant Repair S4- IRC5
  • schelle
    32
    • June 15, 2021 at 9:25 AM
    I want to overtake full control by robot controller. PLC has to be skipped, at final stage disconnected.
    Also, safety signals will be connected on the panel board. Herewith, all safety features related to plc will be also skipped.
  • Master and slave
  • remote mode
