Hello guys,
I got a KRC 2 240 robot ed2005 KSS 5.6. I got a specific location where if an operator will press either the buttons for stop or safety the robot will receive this specific message and then the operator has to enter the robot cell and Ackn. that line in order work with the robot again. I as first line of code some TORQMON limits, but the peak value I monitor with TORQ_DIFF for axis 3 is between 28 or 35 and my set limit is 45. I even tried to run the program with 70% for that axis or cut the limits from the beginning of the program where that point is located and set them after that but I still receive that.
Also is it possible to change the operating mode of the robot from the PLC and Ackn that error from the PLC in order to limit the access in the robot cage?
Thank you guys!
