KUKA RSI: Get $TOOL & $BASE
  • s2007.ravi
  • June 7, 2021 at 8:06 PM
  • s2007.ravi
    14
    585
    Hi All,
    RSI: 3.3.3.267
    KSS: V8.3.320/KUKA8.3
    I have been developing an application to communicate with a KRC4 controller over RSI. I have developed an external UDP Server application (running on my computer) that talks to the robot and fetches some data such as cartesian and axes positions, etc. I have gone through the manuals and tried to find a way to send the real-time values of actual TOOL and BASE to the external application from the robot. However, in the manual and the examples, I could not find any RSI block that I can use in RSI Visual to get these system variables and send over the bus.
    If anyone has achieved this, then please help me with the idea of programming it.
  • colinb83
    13
    102
    • June 7, 2021 at 8:10 PM
    Does your tool and base change?
  • s2007.ravi
    14
    585
    • June 7, 2021 at 8:19 PM
    Quote from colinb83
    Yes, in some of the applications they do change. For example, at the beginning of the src file, the robot motions are w.r.t to $WORLD and then the BASE can change as per the workpiece.
  • SkyeFire
    1,060
    9,456
    • June 7, 2021 at 11:57 PM
    IIRC, there are RSI objects that can access the $SEN_PREA system variables. You might be able to have the SPS assign $TOOL and $BASE values to those variables.
  • s2007.ravi
    14
    585
    • June 8, 2021 at 8:21 PM
    Quote from SkyeFire
    Thanks for the suggestion. I did exactly the same. However, when the submit gets launched or a new value to the current TOOL or BASE gets assigned, it throws an error saying invalid X value or invalid Y value, These errors are random.
    With KRC4, I observed that it throws the above-mentioned errors when the TOOL and BASE are assigned to unknown. Once a valid value is assigned, it works fine. However, when I run the program and current TOOL and BASE get reassigned, the error comes back randomly. I will have to dig into it and find a workaround.
  • colinb83
    13
    102
    • June 8, 2021 at 9:13 PM
    Don't forget you can always ask kuka tech support, some clever guys there that know the tech packs far more than is explained in the documentation
  • SkyeFire
    1,060
    9,456
    • June 9, 2021 at 2:49 PM
    Yes, under certain conditions (cold boot, Program Cancel), $BASE and $TOOL get set to Uninitialized. You get around this by using ON_ERR_PROCEED in your SPS -- if an attempt to copy $BASE or $TOOL into $SEN_PRES returns an error, skip it and keep going.
  • s2007.ravi
    14
    585
    • June 10, 2021 at 7:37 PM
    Sorry for the late reply.
    Thank you SkyeFire for the heads up. For now, I put protection in the code using VARSTATE.
    IF VARSTATE("$BASE") == #INITIALIZED THEN
      $SEN_PREA[1] = $BASE.X
      $SEN_PREA[2] = $BASE.Y
      $SEN_PREA[3] = $BASE.Z
      $SEN_PREA[4] = $BASE.A
      $SEN_PREA[5] = $BASE.B
      $SEN_PREA[6] = $BASE.C
    ENDIF
    I tested the code and it works fine.
  • panic mode
    1,295
    13,130
    • June 11, 2021 at 7:22 AM
    that may work for most cases but ... it is not ideal. you are assuming that someone will always initialize all elements. that is not a safe assumption. it is better to check each element individually if initialized....
    if you don't believe me, simply when you see $base not initialized (shows up as ? on the smartPad), you can try to give it value such as { X 0} using either program or variable monitor.
    or create new program with some test code like this:
    DEF VAR_INIT_TEST()
    DECL FRAME f
    f = {X 0}
    $BASE = f
    IF VARSTATE("$BASE")==#INITIALIZED THEN
    ENDIF
    END
    although you only initialized one element add other five are still not initialized, your check will say that $BASE is initialized (which is not exactly true) and the program will crash when it reaches line 3.
  • SkyeFire
    1,060
    9,456
    • June 11, 2021 at 2:28 PM
    One problem with using VARSTATE in the SPS on certain system variables like $BASE and $TOOL is that the Level 0 interpreter (SPS) and Level 1 Interpreter ("normal" programs, usually with motion) are completely asynchronous.
    This means that, even if VARSTATE shows $BASE as being Initialized, it's possible for $BASE to change to an uninitialized state in between your SPS's VARSTATE check and the next line. I had this happen way back when I first tried doing something similar to what you're attempting now. If you roll the dice often enough, eventually you'll come up snakeeyes.
    The more robust approach is to place a ON_ERR_PROCEED immediately before each $SEN_PREA= line. Maybe follow it with a command to check the $ERR return state and, if there was a fault, fill the $SEN_PREA with deliberate nonsense (like -99999 or something) that will act as a signal to your server to not trust the $SEN_PREA values.
  • s2007.ravi
    14
    585
    • June 20, 2021 at 1:56 PM
    • #11
    panic mode and SkyeFire
    You both are right. The program failed after working fine for a few attempts throwing error KSS01422 i.e. ($variable value Invalid) for one of the sub-elements of $BASE.
    I will modify the code and test on the next available opportunity and port an update here.
Similar Threads
  • How to create custom HMI on KUKA KCP???
    • LCotta
    • November 13, 2014 at 11:08 AM
    • KUKA Robot Forum
  • KUKA Move in #TOOL
    • iljalways
    • June 19, 2018 at 3:57 PM
    • KUKA Robot Forum
  • Kuka workspace error after transferring program
    • p0nder
    • May 3, 2018 at 5:38 PM
    • KUKA Robot Forum
  • Kuka KRC1 - Transferring files between robots
    • maaron
    • March 15, 2018 at 8:04 PM
    • KUKA Robot Forum
  • Milling With KUKA
    • Moriii6530
    • December 4, 2017 at 6:09 AM
    • KUKA Robot Forum
  • Need help with Link b/t SprutCAM & Kuka KR 30/2
    • neeboy74
    • November 30, 2013 at 5:34 AM
    • KUKA Robot Forum
  • about the sequence of calibrating tool frame and base frame in KRC4
    • dinesh_harsoliya
    • August 10, 2017 at 12:45 PM
    • KUKA Robot Forum
  • Using LK_Base (Roboteam) outside inline form
    • MissM
    • June 29, 2017 at 11:08 PM
    • KUKA Robot Forum
