Access $SYSTEM_TIMER in Karel
  • Nono
  • June 7, 2021 at 4:13 PM
  • Nono
    Hi everybody,
    I am looking for a way to count the time when the servos of my robot are on. I found the $SYSTEM_TIME[1].SRV_TOT variable that would do the job but I can't access this variable with my Karel program. I am on a R30iB mini plus controler.
    Thanks!
    :smiling_face:
  • HawkME June 7, 2021 at 5:56 PM
    Moved the thread from forum Manuals, Software and Tools for Fanuc Robots (you should look here first before posting) to forum Fanuc Robot Forum.
  • jmd2777
    34
    193
    • June 7, 2021 at 10:29 PM
    Please post your Karel code and the error that you get.
  • Nono
    • June 8, 2021 at 8:43 AM
    Here is my Karel code:
    IF Day <> $SYS_TIME.$DAY THEN
    IF $SYSTEM_TIME[1].SRV_TOT - Memo_SRV_TIME > 480 THEN
    TIMER_DAY[i] = $SYSTEM_TIME[1].SRV_TOT - Memo_SRV_TIME - 480
    ELSE
    TIMER_DAY[i] = 0
    ENDIF
    Memo_SRV_TIME= $SYSTEM_TIME[1].SRV_TOT
    i=i+1
    ELSE
    Day = $SYS_TIME.$DAY
    ENDIF
    And this is the error:
    C:\Users\NMARILLE\Documents\My Workcells\Arvis2\loc_timer.kl(45)
    45 IF $SYSTEM_TIME[1].SRV_TOT - Memo_SRV_TIME > 480 THEN
    ^ ERROR
    Id must be defined before this use. Id: $SYSTEM_TIME
    thanks
  • HawkME
    568
    3,268
    • June 8, 2021 at 11:35 AM
    Missing a $.
    $SYSTEM_TIME[1].$SRV_TOT
  • Nono
    • June 8, 2021 at 11:58 AM
    Hello HawkME,
    I still have the same error, and in my program $SYSTEM_TIME[1].$SRV_TOT is not written in yellow like other system variables.
    Do you have an idea?
  • jmd2777
    34
    193
    • June 8, 2021 at 2:58 PM
    You need to use the GET_VAR command to read system variables. The syntax is in the Karel user manual.
  • Nono
    • June 9, 2021 at 1:24 PM
    this is working!
    thank you !
    :smiling_face:
Similar Threads
  • Socket messaging between roboguide and PC via c++ code
    • piego
    • June 3, 2021 at 8:29 PM
    • Fanuc Robot Forum
  • Crazy Circular Tracking Idea
    • jariuscs
    • April 1, 2021 at 12:39 AM
    • Fanuc Robot Forum
  • 2D array data in Karel
    • zhaoxiang chen
    • April 7, 2021 at 9:56 PM
    • Fanuc Robot Forum
  • Karel-access to constants present in another program
    • rudolf1385
    • April 2, 2020 at 2:40 PM
    • Fanuc Robot Forum
  • Indirect access of system variables
    • Robot Programmer
    • June 10, 2019 at 10:00 PM
    • Fanuc Robot Forum
  • KAREL INTP-311 (Uninitialized data) while using var_1 FROM prog: ARRAY
    • odojak1715
    • March 29, 2019 at 8:45 AM
    • Fanuc Robot Forum
  • KAREL TP scripts
    • sweck
    • August 15, 2017 at 7:07 PM
    • Fanuc Robot Forum
  • System Variable
