Hello all
Question from KUKA KRC4 KSS 8.3.
I was wondering if we can adapt and modify (or if someone already experimented it) the KUKA constants in the config.dat which is directly linked with the BAS.SRC file.
Parameters like cp velocity, swivel velocity, acceleration and jerk.
Before changing it, the first question that came to my mind is the load on TCP and load on the arm 3. Modifying these parameters, I assume would certainly have an impact on the movement and the path followed. However, with load on TCP to the maximum allowable load for the specific robot, would make the robot work in its 101% and would impact the life of drives and other components.
Do we have any tool, that can calculate the max allowable value for the above said parameters or materials which can guide over this topic.
